Cold start up issue
  • Cold start up issue
    Okay I am not sure if I am being paranoid...... when I start the car up after it has being sitting overnight it turns over but when you give it some pedal it just cuts out.... You do that 2 or three times and then starts up fine and you have no problems for the rest of the day. Talked to the previous owner and he seems to think its normal. I changed the spark plugs this morning and hasn't made much of a difference. I done plenty of research on the countless forums and I haven't got a definite answer.
    Ryan
    You should check your fuel pressure ---- may have a leaky fuel pressure regulator
      Locate the fuel pump relay and work out how to jump it. So the pump runs constantly. Then try starting, see how it goes. I wonder if the pressure is dropping overnight and the pump isn't priming enough for a start.
        Okay thanks for the quick reply..... After a bit of research testing fuel pressure reg is something I should be able to do. Do you think I should be checking leads and dist cap as well.
        Sent from my SM-G900I using Tapatalk
          is the pump priming as soon as you get lights on the dash (on position?). Its quite loud
          'I spent a lot of money on booze, birds and fast cars. The rest I just squandered' - George Best
            Yeah pretty sure its priming on start up.... Just doesn't get that second kick that keeps it idling. Went to repco today to buy a fuel injection pressure tester but $500 just isnt worth it. Im thinking of just buying the fuel pressure regulator and taking the chance that it will fix it.
              Trade tools have one for 130
              Not far off buying one myself.
                Whats that a tester or the fpr
                  Sorry dum question gotta be the tester
                    Fuel system in general. depends where you plumb it in.
                      Do you have access to a laptop and VCDS.
                      Best bloody thing to start problem solving. If that doesnt deliver any results you are like me and chasing your tail.
                        Buy the time i spend the coin diagnosing this problem its gonna be almost as much as getting a Vag mechanic to do It...... I may have to let the pro do it........ Thanks for the help guys
                          Okay got the car scanned. Came up with faulty speed sensor... implausible signal. The guy cleared fault and said would be a good to rescan and see if fault come up again on a later date
                            Good work!
