Downpipe
AND when the sub-frame was out... in goes a 3" downpipe.
The cat is the easy part to remove... broken bolts. Oops!
The downpipe not so easy. Did mine through removing the driver's driveshaft, driveshaft heat shield and was able to access the two bottom ones that way using the tiniest movements to undo the bolt. Once cracked the ratchet was only clicking once due to space restrictions. But it was one click at a time until the nuts came off
With subframe/ driveshaft off the bottom nuts are easily undone. Now the top one.... grrrr
I was super puzzled how to get the top nut undone but ended up using the 3/8" ratchet w/ universal joint and an extension. Thank F i was able to do it as it would've been heaps harder to take off the exhaust manifold.
Got it all off! woo! Needed to remove the bolt (below - the hex head) from behind the foot rest plate that connects the steering wheel to the steering rack to be able to lower the rack down enough to help remove the downpipe
Old VS. New (wish it would stay that clean)
and almost done...
This is before the steering rack is re-attached ^^^
All in!!!
Apologies for the whack photos... the forum software seems to rotate them on its own. 1st pic shows clearance from the steering rack heat shield, and other two photos are from the turbo, down at different angles
and almost done...
All in!!!
