Audi 1.9 SD engine info
  • Audi 1.9 SD engine info
    Hi all ........ I'm putting an Audi 1.9 SD engine into a Mk 1 Golf. I noticed today that it has a G grind. I'm wondering if this might be the original cam fitted at the factory. This is the 1845 cc engine that runs 10.3 : 1 comp and puts out 110 bhp.
    Cheers .... Geoff
    Trying to figure it out now Geoff.
    So far I've got part number #053 100 103 X for the short engine.
    83 kw 113Hp
    Standard camshaft is the G Grind by the looks of it part number 026 109 101 G
    Fitted to Audi 80s 09/86 - > 07/88
    Pistons are 82.5mm 053 107 065
    Crankshaft is 026 105 101E
    Rods 026 198 401A
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
      Getting closer
      1988 Audi 80 1.9 E
      Bore × stroke 82.50 mm × 86.40 mm
      Cylinders S-4
      Displacement 1.8 litre
      1847 cc
      Type SOHC
      2 valves per cylinder
      8 valves in total Construction
      Sump Wet sumped
      Compression ratio 10.50:1
      Fuel system Bosch KE-Jetronic fuel injection
      Maximum power(DIN) 112.5 PS (111 bhp) (82.8 kW) @ 5800 rpm Specific output 60.1 bhp/litre
      0.98 bhp/cu in
      Maximum torque (DIN) 160.0 Nm (118 ft·lb) (16.3 kgm)@ 3400 rpm bmep 1088.6 kPa (157.9 psi)
      Specific torque 86.63 Nm/litre
      Main bearings 5
      Coolant Water
      Bore/stroke ratio 0.95
      Unitary capacity 461.75 cc/cylinder
      Aspiration Normal
      7? MK1 Caddy
      12 Amarok
        Thanks for that Pete. Wealth of info as usual. Cheers. Geoff
          Now that I've got the part number for that Cam I should be able to find the specs for it in the Bentley manual.
          There's some interesting cross compatibility going on with the block though which might help you.
          It seems the same basic block is suggested as a universal replacement for motors from 1.6L to 1.9L, I'm trying to clarify that, the parts listings can be cryptic.
          7? MK1 Caddy
          12 Amarok
