AUDI A3 _BMN engine (2007) - HELP
  • AUDI A3 _BMN engine (2007) - HELP
    Hi guys,
    I need help with my A3 Diesel Audi BNM engine. It has number of issues it seems but not logging all of them in the scan.
    1. Glow plugs heater Spiral icon flashing constantly.
    2. Engine mil light on constantly ( goes of when engine drives)
    3. ESP Fault lights flashing on dash constantly
    4.DPF filter icon flashing constantly (goes off when driving)
    I have also included scans before few days old. Underneath.
    The car with full charged battery highest CC's wont start until I use the diesel start spray. It drives for 15min then starts to shake and eventually turns off. After that at working temperature it wont turn back on.
    While cranking at the start (post run) the only error that is different is the Engine Speed error and Transmission - ABS control module... Those errors clear on VCDS.
    Any help is appreciated.
    Al
    Here is the scan.
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(VMWare)
    VCDS Version 18.2.0.3
    Data version: 20180212 DS287.0
    Ross-Tech: Home
    Chassis Type: 8P (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: Malfunction 0010
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-018-BMN.clb
    Part No SW: 03G 906 018 DN HW: 03G 906 018 DN
    Component: R4 2.0l PPD1.2 G 1247
    Revision: --H42--- Serial number: AUX7Z0G5FNS0ZG
    Coding: 0000078
    Shop #: WSC 12345 822 05314
    VCID: 74E7EFF0171804E40C-8021
    1 Fault Found:
    008194 - Particulate Trap Bank 1
    P2002 - 006 - Efficiency Below Threshold
    Freeze Frame:
    Fault Status: 11010001
    Fault Priority: 5
    Fault Frequency: 5
    Reset counter: 40
    Mileage: 76220 km
    Time Indication: 0
    Date: 2018.04.26
    Time: 01:18:11
    Freeze Frame:
    RPM: 800 /min
    Torque: 40.0 Nm
    Speed: 0.0 km/h
    (no units): 2.0
    Pressure: 0.0 mbar
    Lambda: 19.8 %
    Time: 4492.8 s
    Readiness: N/A
    Address 02: Auto Trans Labels: 02E-927-770.clb
    Part No SW: 02E 300 044 L HW: 02E 927 770 AE
    Component: GSG DSG 081 1402
    Revision: 04608010 Serial number: 00000706251012
    Coding: 0000020
    Shop #: WSC 00028 028 00001
    VCID: 1E33ED58C914FEB40A-804B
    No fault code found.
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
    Component: ESP FRONT MK60 0101
    Revision: 00H11001
    Coding: 0023170
    Shop #: WSC 31220 822 96270
    VCID: 73E5ECEC121603DC15-8027
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 AG HW: 8P0 820 043 AG
    Component: KlimavollautomatH19 0420
    Revision: 156554 Serial number: 8P0820043AG
    Shop #: WSC 06314 000 00000
    VCID: 71E9E6E4680A31CCE7-8025
    Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
    Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
    Component: Bordnetz-SG H54 2501
    Revision: 00H54000 Serial number: 00000007278680
    Coding: 01880F01B0141000471600001600000000085E175C01000000 0000000000
    Shop #: WSC 06314 000 08192
    VCID: 458162340C02CD6C6B-8011
    Subsystem 1 - Part No: 8P2 955 119 E Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 L HW: 8P0 959 655 L
    Component: Airbag 9.41 H01 4210
    Revision: 91H01421 Serial number: 003CP0000HES
    Coding: 0070612
    VCID: 4B95540C2A663B1CBD-801F
    Subsystem 1 - Serial number: 6332DRB404C30A93O
    Subsystem 2 - Serial number: 6342DRB404C2CBA6+
    Subsystem 3 - Serial number: 63528RB402A1E68AV
    Subsystem 4 - Serial number: 63628RB402A1E58F-
    Subsystem 5 - Serial number: 63747RB4028897DA/
    Subsystem 6 - Serial number: 63847RB402889856U
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H36 0070
    Coding: 0012142
    VCID: 41897624182AE14C57-8015
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 H02 0030
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
    Part No SW: 8P0 920 931 E HW: 8P0 920 931 E
    Component: KOMBIINSTR. VDO H20 0640
    Revision: D0H20001 Serial number: 2245G001009636
    Coding: 0000728
    Shop #: WSC 31870 067 57207
    VCID: 356112F45CE25DECFB-8061
    Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
    Part No SW: 1K0 907 530 L HW: 1K0 907 951
    Component: J533__Gateway H15 0180
    Revision: H15 Serial number: 1400K07624813D
    Coding: ED807F061002022103
    VCID: 306F23E0A38078C4A8-8065
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H20001 Serial number: AUX7Z0G5FNS0ZG
    Shop #: WSC 07482 002 1048576
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
    Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
    Component: Tuer-SG H03 0040
    Coding: 0000688
    VCID: 43857C2C0236F35C45-8017
    Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
    Part No: 1K2 909 144 M
    Component: EPS_ZFLS Kl.069 H08 1901
    Shop #: WSC 03122 822 96270
    VCID: 366315F841E456F4F2-8063
    1 Fault Found:
    00778 - Steering Angle Sensor (G85)
    000 - -
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 L
    Component: KSG H10 0080
    Coding: 1880202002186D0985054C9F0167
    Subsystem 1 - Component: Sounder n.mounted
    Subsystem 2 - Component: NGS n.mounted
    Subsystem 3 - Component: IRUE n.mounted
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P4 035 382 D HW: 8P4 035 382 D
    Component: AB2 SUBWOOFERBOXH06 0180
    Revision: 00005 Serial number: 30674703009649
    Shop #: WSC 00000 000 00000
    Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
    Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
    Coding: 0000688
    VCID: 44877F300738F4647C-8011
    Address 56: Radio Labels: 8J0-035-1xx-56.clb
    Part No SW: 8P0 035 186 G HW: 8P0 035 186 G
    Component: R Concert2+ H17 0240
    Revision: 00H17000 Serial number: AUZ1Z3G9135395
    Coding: 0210211
    Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
    Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
    Component: Tuer-SG H04 0040
    Coding: 0000144
    Shop #: WSC 06314 000 1012544
    1 Fault Found:
    00098 - Rear Left Central Locking (Safe) Motor (V163)
    012 - Electrical Fault in Circuit
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
    Coding: 0000144
    VCID: 428B79281D2CFA544E-8017
      Pretty simple reading from the VCDS logs
      Your DPF is full.
      Go and get a professional opinion but to me, it’s obvious.
      You may get away with a chemical clean out, you may need a new core.
      You can have them cut out, and Karcher the crap out of the filter core, which has had some results.
      Otherwise you can delete it, but costs a bit more and isn’t considered “Kosher” by many
        Yeah, looks like the DPF is blocked.
        Steering angle sensor fault is probably due to low battery voltage, and needs a basic re-learn.
        '07 Transporter 1.9 TDI
        '01 Beetle 2.0
          Hey guys, thanks for the reply. I have run the car after start with the diesel spray. DPF error goes away immediately as you start driving but the car goes in limp mode in 20min time. This suggest the DPF error is not related to car driving as compression and power is great. I have checked all the DPF related sensors and are all fine. DPF returns after second attempt at turning on the engine but also so does the ESP fault error. They seem to be constant at the ignition stage and can not be cleared. ESP fault is not registered by VCDS anywhere. Could this be electrical issue ..
          Al
            Umai , steering angle sensor resets it self every time car goes to drive . It only registers on false start if there is an issue.
            That part is good. Not a problem.
              Also guys , DPF is clean as I have inspected the unit .
                How did you inspect it?
                Have you gone into the Measurement Channels and found the soot and ash levels?
                  Sounds like you've got it under control.
                  Let us know how you go.
                  '01 Beetle 2.0
                    Hey,
                    I took the entire thing DPF off and piping . No soot what so ever , normal ash level - minimal dirt.
                    Measuring blocks fluctuate and as I don't relative comparison indicator I can not tell. What is normal for BMN engine.
                    For the age and mileage the car is dirty but not blocked by any means.
                      I didn't chemically clean the DPF , noting comes out of it no dust.
                        I’m impressed you did that. Most forum goers aren’t that savvy.
                        Greg Roles spent a few hours with a Karcher, pushing the ash back out of the core, then drying it in the oven before putting it back in.
                        So as I understood it, the ash/soot doesn’t just fall out, it needs to be pushed out
                          To keep this simple, I know lots of you guys looked at the youtube videos but when I took the DPF off , I could see through the cells.
                          Anyway , Im gone past the DPF itself. Looking into combination of sensors again.
                          Al
                            Your ECU thinks your DPF is blocked.
                            Do a forced regen
                            Diesel Particle Filter Emergency Regeneration - Ross-Tech Wiki
                            you may need to reset the dpf loading
                            I had exactly the same issue.
