Vwaus
  • VIC Vwaus
    Hi guy's. I have a 2002 bora v5 great ride. The a/c will only blow hot air no cold at all, had in in at my mechanic checked everything; found no faults but cannot get compressor to engage. Has any one else had this problem ans what was the fix. Just adding has no one had this problem?
    Really nobody has had this problem?
      No one is looking at vehicle problems in the newbies section mate. It's for introducing yourself.
      However, like most AC systems, there's high and low pressure switches in the pipes. Either of which would stop it engaging. Assuming there's adequate gas pressure.
      Also the clutch could be gone on the compressor. Hard to imagine a mechanic that couldn't pick one of those four things with reasonable speed.
      Best of luck.
        Thanks for your reply.Didn't know i could not post repairs here.Mecanic tells me he checked all four probs you suggest but still no avail. Any other thoughts.
          The point is, if you post in the appropriate section you'll get a response.
          I have no other ideas for you.
            Gavin.
            Being new i don't know where to post can you assist?
