2007 MK5 jetta
  • 2007 MK5 jetta
    Hi everyone, i have a 2007 tdi jetta, and i am from victoria. i found this site when i was searching for my solution to the problem that i encountered with my tdi jetta.
    can anyone help me with this issues.
    1. the car sounds weird when starting, it sounds like it doesn't want to start no matter cold or hot. i thought about the glow plugs, but i searched it up on youtube, the sound is not the same when it is caused by glowplug issues. so i am not sure what is causing the problem. the car do start, but it sounds disgusting and sounds like its gonna die
    2. Also, the speedo area always say the drivers door is open, and it doesn't lock, the issue is not consistent, like sometimes it doesnt show up, but sometimes the light comes up, can anyone help me with this issue
    thanks for reading
    Starting issue could just be the battery, have it checked.
    The door issue is common on all VWs for the last 15 years or so. The locks have gremlins, yours probably has a broken wire/poor connection from the micro switch which monitors the position of the latch. So it sees the door as open all the time, it won't lock when the door is open.
    If you are handy with a soldering iron then pull out the tools or get a new lock otherwise.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
      I also agree about the battery. At the first sign of trouble with starting I would replace it. If you do a search on here you will find other discussions here about this topic. Winter is hard on batteries & the TDI needs a strong battery for trouble free starting.
      Numerous Mk1 Golf diesels
        thank you very much for the help and advice!!
        however, for the lock issue, i have already changed the lock on that door(not all 4 of them)both the module and the lock. but the issue is still here
        and for the starting problem, i connected an external battery to the battery (like when you jump start a car with a car battery), but the problem is still there. so i am not sure if it is the battery problem...
        so are there any other possible ways i can fix the problems? thanks
