Hello Can anyone help me with Vag Com coding in Sydney?
  • NSW Hello Can anyone help me with Vag Com coding in Sydney?
    I have just installed a RNS 510 system on a Golf Mk6 2012. The sat nav works fine, however there is no direction displayed on the MFD. Everything else seems to be working fine. I have done a reset on the RNS system, that did not fix the issue. I believe a vag coding will be required. Can anyone help me please with a vag coding? I live in Sydney Eastern suburb. Thanks.
    read this thread
    VAG-COM scanning, who can help
    Hawkedit: Fixed link from .org to .com
      As you've found out the RNS510 install works perfectly with no coding but doesn't display anything on the MFD. It's a simple coding switch to get that going.
      I'm in SW Sydney if you're out this way ever, but I'm sure there is probably someone closer
        Thank you all for your quick responses. The problem has been resolved, thanks to member Kamold. Cheers.
          Originally posted by Hillbilly View Post
          read this thread
          ? How did that happen as I copied and pasted the link.
          Strange LOL
            No idea unless you're copying an existing (old) link from before the domain change. It's all supposed to redirect (and does) but if it's using the .org.au domain it tends to forget you're logged until you click on a .com.au address.
              I opened the thread and copied the address from the header bar so strange as it opened OK
