Learning about my car
  • Learning about my car
    I found this forum very helpful and decided to join. MK5 MY09 full optioned. I'm trying to find out if my touch screen (sat nav w i-pod Bluetooth) that has a phone button requires a module to make it work. At the present it only serves as a mute button however "Phone" is listed. It will not pair and doesn't appear to be set up for phone...module needed? what is the part required? Is it easy and a DYI or a little tricky?
    If you have the factory RNS510 system then yes, the bluetooth module is a separate unit.
    Depending which MFD you have you can install an OEM bluetooth module fairly easily. However it will likely also require the car to be coded correctly with VCDS.
    You will need either this unit if you have the full height red MFD,
    or this unit if you have the half-height red MFD.
    Relatively straight forward to install (even thought the MkV is annoying to remove the head unit with having to pull out a bit more trim than should strictly be the case...)
    Refer to this thread for details of forum members who can assist with install and coding.
      That was a very helpful. Thanks! Not to add the sub and amp ...always something fun to do.
        Now to add the sub and amp...not, not.
