ok guys ive lowered my mk4 golf and a problem has occurred, as the road is bumpy my drive shaft rubs against the sway bar, is this a common problem for mk4 golfs if its lowered to much or i might have something out of place as ive hit the side of a barrier when i was having fun threw the mountains few months back but car wasnt lowered when i had the incident.
Low life problems !!
Originally posted by aliVEEDUB View Postok guys ive lowered my mk4 golf and a problem has occurred, as the road is bumpy my drive shaft rubs against the sway bar, is this a common problem for mk4 golfs if its lowered to much or i might have something out of place as ive hit the side of a barrier when i was having fun threw the mountains few months back but car wasnt lowered when i had the incident.
hope that helps
The exact same thing happenned to me...i was having fun on a road in some mountains and after one corner, it all of sudden started scraping. I was told to get drop links for the swaybar which I did but they didnt work - only caused more scraping. And I didnt want to raise it so I bought a H&R swaybar which has more clearance - got that put in and now it doesnt rub!
general rule with mk4 FWD is after a 40mm drop the sway bar will start to cause problems.
Some people seem to get away with a 50mm or so drop.
H&R and one or two other brands apparently have it sorted (even for bagged cars)
end links only work to a point also
I removed my stock sway bar and replaced it with a whiteline (big mistake!), ended up having the whiteline removed and run no sway.
There is a down side of more body roll, but I think there is less under steer now. and no sway lets the suspension move more freely which seems to give a softer ride
I can't say for Mk4 but on my Tig I had to add adjustable links and also adjust the setting on the sway bar so I got clearance from my tail shaft. Also if your sway bar shifts (side-to-side) this may also effect the clearance so re-centring the sway bar may be enough.
Originally posted by aliVEEDUB View Postok guys ive lowered my mk4 golf and a problem has occurred, as the road is bumpy my drive shaft rubs against the sway bar, is this a common problem for mk4 golfs if its lowered to much or i might have something out of place as ive hit the side of a barrier when i was having fun threw the mountains few months back but car wasnt lowered when i had the incident.carandimage The place where Off-Topic is On-Topic
Originally posted by eri_12 View PostThe exact same thing happenned to me...i was having fun on a road in some mountains and after one corner, it all of sudden started scraping. I was told to get drop links for the swaybar which I did but they didnt work - only caused more scraping. And I didnt want to raise it so I bought a H&R swaybar which has more clearance - got that put in and now it doesnt rub!
Re: Low life problems !!
Originally posted by aliVEEDUB View Postwhere can i find a H&R sway bar from ??
I had the same problem man, also put in a whiteline and like Dylan said it was a bad idea, took that out and am not running one at the moment but I think I'll go a H&R front and rear soon too.
A guy on VwVortex also told me a while ago that he ran a mk4 R32 swaybar on both of his (non R32) Mk4's without a problem but I can't confirm if that would actually work or not.Last edited by SLAJ; 07-07-2013, 10:01 PM.
I bought mine off ebay - a seller in USA. This is the exact one I bought:
H R 98 10 VW Beetle Golf Jetta IV VR6 TDI 1 8T Cabrio Wagon 26mm Front Sway BAR | eBay
Except I did have to pay an extra $50 or so for postage because it was too big to send with usps and they had to send with ups instead which got here way quicker anyway.
Edit: I also used the stock linksLast edited by eri_12; 07-07-2013, 07:39 PM.
My MK4 is on lowered springs, whiteline swaybar and the whiteline adjustable links and I have no rubbing at all.
The standard links are not your friend.MK4 GTI: Custom Code Stage 2, K03S, 42DD exhaust, Bilsteins, whiteline F&R, 312mm brakes
MK6 GTI: MY13, DSG , very stock
Ducati 749
My drive shaft snapped out if place where it connects to the gearboxes the bearings **** them selves lol. My mechanic is making a spacer to make the drive shaft longer guess that should help out a little... But thanks guys for help goin to order the after market sway bar soon as car back on the road !!!
Originally posted by aliVEEDUB View PostMy drive shaft snapped out if place where it connects to the gearboxes the bearings **** them selves lol. My mechanic is making a spacer to make the drive shaft longer guess that should help out a little... But thanks guys for help goin to order the after market sway bar soon as car back on the road !!!
"I only post on Facebook if I know i am going to get likes" - M
I have the same issue you've mentioned and I'm on coils with standard front swaybar and FK adjustable drop links. I wouldn't really recommend the drop links after a certain amount of lowering as they're not going to to solve all rubbing problems. One of mine actually broke and so I went back to the standard drop link on that side and haven't noticed any further issues there.
I Might have to look into swaybar removal if I want to go lower. That said, I'm fond of it handling well & don't mind a harsher ride as a result of keeping the swaybar in place.Mk3.Mk4.Mk1
My Mk1 Project
