Hiya
My Mk2 golf Gear box was making some horrid noises, I noted the diff was wobbling all over the place with the drive shafts off, so I’ve pulled it out and stripped it down. Diff and bearing look ok, I assume they are just worn so I’ll replace all bearing etc.
The scary part! My reverse Gear cog has chunks missing and is in horrid shape. Any idea where I can get another one ? or can they be restored?
I haven’t found any at wrecking yards in Brisbane.
It’s a 020 type. Any help would be appreciated.
Ps as I will need to undertake a gearbox rebuild any recommended store advice?
Pss I will also be redoing the engine as well, 8v. – bore has only tiniest of lips, didn’t notice it unless I really concentrate. Could I get away with just new rings, bearing etc?
