Been a fan of VWs for a long time, having had several over many years and migrating to a Porsche then the kids came and downscaled to Audis and now back to VWs for both self and wife. Have had a Passat TDI for 3 years, great car but filled with troubles. Have had the DSP and turbo replaced under warranty and now it is in hospital waiting for injector replacement. Currently 6mths out of warranty so nervous that it won't be covered by the factory warranty and
unfortunately all those good feelings about VW are slowly drifting away. We shall see.
Passat TDI MY08 troubles
Has the vehicle always been dealer serviced? This will usually help with the next step:
Have you asked the service department for some leniency/generosity from VAG to consider 'assisting' with costs?
If you don't ask.......you'll never know (for sure)MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
2008 GOLF .:R32/5DR DBPE DSG/SUNROOF/RNS510/PRIVACY TINT/CONTI SC3s/MILLTEK CATBACK NON-RES/9W2 BT/"MYR-032"
Print out the Injector failure thread in the diesel section and drop it in to them. It's a common problem, don't be told otherwise. If you have had VW servicing, they should come to the party. Even if you haven't, you've EVERY right to fight for a reduced cost in the least, as these are non servicable parts that would be expected to last a reasonable term. If it goes sour, PM me, there are cogs in motion on this issue.2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
Injectors fixed but now exhaust emission light on
Like most things, an acceptable result from VW to my injector problem (they accepted claim for warranty even though it was out 6 months and yes, always dealer serviced so guess that helped) meant I didn't come back to this forum. However now my exhaust emission failure lamp is on and I am dreading the impact of more time, money, inconvenience, etc. Thinking seriously now of ditching the beast and going to something like an Audi. Was good for a while but one can only take so much!
