hi there
  • hi there
    this is my first time posting in a forum i recently bought a jetta 2 csi 1.8 8valve hardly a month later and the oil pump retired taking the crank with it after lots of bad advice i put 82.5 mm pistons in which was 2 or 3 mm short of the deck then had the small ends of the conrods offsect and the block decked also had a schrick 276 cam installed the thing is dont no ccs or compression or if its going to make more power thats why im here to get betta advice hopefully lol
    Welcome all the way from Australia
    Bad Luck on the Jetta
    What year is it ?
    - Ben
    2008 Jetta 2.0L FSI
      thanks for the reply its 1991 engine code ev any more advice is weclcome
        You have opened a bag of worms I think. What were the pistons? Working out engine capacity isn't hard, wikipedia and google will give you a formula.
        Have you had 2 to 3 mm taken off the block??? You need to talk specifics here, that makes all the difference. I think a safer option would be to get another block and start again. You can use any 1781 cc bottom end, carb injection, doesn't matter. Even a late 1600 would work, the bore is the same, just the cranks would need swapping to an 1800.
          i agree about the worms the engine was neva to be modded just wanted to go a bit oversize and i was suplied the incorrect piston wich was sent to the machinast at the end of dthe day when the mechanic started to assemble he saw that the pistons were actually 3mm short of the block the rest of my headaches was to get the pistons level with the block thats why the block was decked 0.4mm and the conrods were offset 2mm with larger wrist pins to acommodate that later i found out the pistons are actually 2.0 vw pistons if i could just find the parts salesman he would be sorry a pity he was fired thx for the reply the rest of the engine is std
