Hey guys and girls,
I have just put a deposit down on a Mk3 GL golf 5spd pending RACV check on Monday. I've always been a massive fan of the VW range growing up around Kombis, beetles and Type 3's. However personally only ever owned and moddified older Jap cars; Dattos, Corollas, Geminis and rotors. So im fairly excited to get it, add to that i have no car as it was written off last week, hence me buying the golf.
I have a few issues with the car i have purchased, i'll list them here but i'm not sure if this is the correct sub-forum to do so, if someone could help me out with the right forum?
Problems:
Tacho and speedo don't work - I assume this to be a earthing problem/plug loose as its both of them?
Power windows don't work/very slow, after speaking to a mate about this he seems to remember his sister had the same problem with her golf. Are power window motors a common part to fail in golfs/Mk3s? And if so what fails? i assume the bushes in the motor?
other then that the cars lovely to drive, i use it primarily to get to uni (bach Mech Engineer) and back, So its just my daily.
My other car is a 1977 Isuzu PF50, Delivered on the Aus market as a Holden Gemini; 1.8L SOHC, Turbo running 10Psi with a T28, Fuel injection (came carby) using a megasquirt ECU, custom manifolds, 350cc injectors. Aiming for around 200kw. But that's another story.
I appreciate any help that you guys could give me and look forward to being an active member of your forums,
Thanks,
Pat
Problems:
Thanks,
Pat
