used golf tips
  • used golf tips
    Hi All first time on this forum basically I've just bought the wife a used 2014 golf TSI with 130000 ks but has a full service history done by VW just as we done the deal the dealer checked the log book which did not have the timing belt changed at 105 ks ticked so he said as we dont know if it was or not thier going to replace it now anyway at no cost to me (couldnt believe it an honest dealer ? is there such a thing ?) anyhow I said while your in there you might as well change the water pump and they said there is really no need to as it doesnt even mention a replacment time I even offered to pay for it myself but they still insisted I didnt need to , cant believe that either , any how your thoughts would be appreciated and any hints tips known issues etc also what could you expect this car to do in terms of high mieage will it do the same amount of K's again ?
    any help is appreciated
    Thanks in advance
    Dave
    I have no experience with your engine but with my van I drove it until it started to leak in the water pump after the seal started to leak.
    This was around 130ish K & the impeller was starting to lightly rub in the block.
    Some people say the new belts will outlast the water pump. If it was mine, I would replace the pump.
    Numerous Mk1 Golf diesels
      What's the engine code on this golf?
        Dont know what the code is but its a 2014 Golf TSI and the water pump is on the opposite side to the timing belt , one other queery weve switched the stop start feature to off multiple times but it still keeps coming back on is this normal as I think its a stupid idea you might save a smidgen on fuel but all your really doing is wearing out the battery and starter motor a lot faster than it needs to be ?
          S/S resets after you turn car off but can be coded out to never work again Starter and battery are built to take it. Do NOT take anyones advice to pull a certain wire off the battery as that is the sender for battery charge and if you do that will ruin your battery faster. Despite some saying it wont hurt IT WILL.
            Its still under the statuary 3 month warranty from the dealer so I wonder if they would reprogram it for me ? and didnt know about disconnecting it so a big thank you for that interesting that some forums say it will reduce battery life span and some dont which is another reason I'd like it permanently gone I honestly cant see that s/s constanly does any good for a car just MHO
              The dealer WONT reprogram it and will probably deny it can be done Ask if someone in your locality has an OBDELEVEN as it takes 5 mins to do at the most .
              S/S is all about emissions rather than fuel saving. My Passat had it and never turned it off and battery lasted ok as did the starter. Forum opinions are like a**holes everyone has one and not all are perfect. Myself Excepted ROFL
                LOL so true but thanks for the input ANY help is appreciated theres just one more queery I have and its the longevity of the engine 130000Ks ia not a huge amount in todays technologybut as it has had a FULL service history Im wondering how long does a 1.4 Ltr engine go ? do VW s last as long as thier reputation says ? BTW we're in Perth WA bloody hot at the mo'...................
                  Get 1 of these, no need to program anything and it takes less than 10mins to fit.
                  Car Automatic Stop Start Engine Cable System Plug with Tool For VW Golf 7 7.5 B8 | eBay
                  Works great.
                    Works great.
                    Exactly what I was needing many thanks mate that was really appreciated
                    Dave
