Golf Cabrio 1998 AGG engine no spark
  • NSW Golf Cabrio 1998 AGG engine no spark
    Hi guys.
    I am in a tight spot at the moment my mk3 cut out on the freeway, towed it to an old friends place in Bateau Bay 2260 NSW, as it will not start
    First thing i found was the crank positioning sensor insualation was crumbly and coming apart
    So i replaced the crank sensor..... still no start
    checked injector pulse with a noid light and they are working, fuel pump circulating fuel
    just no spark
    I am thinking the CPS may have nuked the ECU? backfed up the signal cable into ECU?
    I have tried a known working coil
    I cannot get a pulse on the coil trigger wire (from ECU)
    I do however have a spare ecu on its way from a mate, if this then fires the car ( immobiliser will soon stop it)
    How can i get the ECU reprogrammed to suit the car key, or does anyone have an operative tool to do the job?
    I am open to all suggestions and advice on this as i just put new shocks and exhaust on the car the week before it karked.
    thanks for all answers
    If anyone has
