Hi all, recently (July) purchased a 2003 T4 TDI SWB syncro.
Slowly working my way through maintenance issues. So far done timing and injection belts, tensioners, water pump. Replaced all engine and gearbox fluids and filters. Fitted cruise control, repaired wiper switch, fixed intermittent wipers ("99" relay had been swapped into incorrect location). Repaired fuel sender to fix extreme hard starting from air leaks into fuel system just under 1/2 tank full. Built a rock n roll bed with slide out kitchen bench. Replaced faulty igntion switch.
Next to do list is fix air con, modify and fit second hand bull bar, build rear wheel carrier. Auxiliary battery electrics for rear camper stuff. Maybe look at remapping? Tidy up electrics where some idiot has fitted a second immobiliser over the top of the standard one.
Any tips on to do list items gratefully accepted!
Other interests: motorcycles Honda xl350, BMW K100, Yamaha XS 1100. Sidecars. Peugeot 308 HDI. Navara STX diesel. Workshop time welding, lathe, milling machine.
cheers,
Brewer.
cheers,
Brewer.
