G-8VXWWTRHPN Gday - VWWatercooled Australia
Gday
  • NSW Gday
    Hi There,
    Wonder if someone can make sense of the connection below.
    I am assuming I'm to solder these cables to the harness with the 1 to 26 pins connector but the
    description below does not appear to match the description on the drawing of the RNS unit.
    VW Amarok High line Rear Camera kit - 2H0907441
    There is four wires: Power (RED), Ground (BLACK) and Can + (ORANGE) and Can - (BROWN) to get hooked up. All of these get tapped behind the RNS/RCD510 and it's worth noting that the pin out is listed on the device anyway if you want to double check:
    Pin 9 - CAN+ (Wire Orange/White)
    Pin 10 - CAN- (Wire Brown/White)
    Pin 12 - Ground (BROWN)
    Pin 15 - +12v (YELLOW/RED)
    Hi transporter1, I know that your first post has to be in the Newbies Corner but the people who can most likely help you probably won't see it here. Copy and paste it here instead http://www.vwwatercooled.com/forums/f78/
