New Here
  • New Here
    Hello all!
    My name is Brett. I own a 2015 Audi A3 8V Quattro that I've been modifying.
    I noticed how engaged your members were in helping address issues, and I'm hoping to have some help too.
    I am having some coding issues in my computer that's throwing fault codes and I hope somebody can help me.
    Thank you!
    @dv52, especially your help with hex and long coding. I hope you or someone can help me.
      Here is the main issue I'm having:
      09 Central Electrics
      System description: BCM MQBAB MNA
      Software number: 5Q0937085AB
      Software version: 0134
      Hardware number: 5Q0937085AB
      Hardware version: H18
      Serial number: 01011414200106
      ODX name: EV_BCMCONTI
      ODX version: 013000
      Long coding: 04151A46C04122F541C0400451100700080000000000000000 0000000000
      Subsystems:
      System description: WWS371 140604
      Software version: 0585
      Hardware version: 042
      Serial number: 140607030124
      Long coding: 0A47F7
      System description: G397_RLFS
      Software version: 0002
      Hardware version: H06
      Serial number: 22735077
      Long coding: 00006C
      System description: E1 - LDS MQB
      Software version: 0032
      Hardware version: H05
      Serial number: 10 04 2014 00001013
      System description: Sirene, DWA
      Software version: 0311
      Hardware version: 004
      Serial number: 00000000000029984738
      System description: J245 PS73.014
      Software version: 0007
      Hardware version: H02
      Serial number: WOO29915178
      Long coding: 101F00
      Trouble codes:
      U101400 - Control module incorrectly coded
      static
        And a gateway issue:
        19 Gateway
        System description: GW MQB High
        Software number: 5Q0907530T
        Software version: 2186
        Hardware number: 5Q0907530M
        Hardware version: 212
        Serial number: 10061410801431
        ODX name: EV_GatewConti
        ODX version: 011017
        Long coding: 0101000820085A005B00020C180B0000000101000000000000 0000000000
        Subsystems:
        System description: E221 - MFL
        Software version: 0014
        Serial number: 04 06 2014 E0005777
        Trouble codes:
        U106A00 - Digital sound system control module No Communication
        static
          19 Gateway
          ODX version: 011017
          Subsystems:
          Trouble codes:
          static
          Welcome to the forum
          First thing you need to do is post your full autoscan.
          Do you (or did you) have a factory fitted amplifier?
          What have you done (or tried to do) with coding or adaptation changes to these modules?
          Do you have an autoscan from before you started playing around?
          If so post that also.
            I was able to remove the code for 19. I tried modifying the Bang and Olufsen module in OBD11.
            My only issue now is 09, central electronics.
            I don't have VCDS, only OBD11. How would I scan and post a full scan?
            I have the factory Bang and Olufsen sound system with an aftermarket subwoofer and aftermarket subwoofer amplifier.
              I'm also getting P003000 - O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor after replacing both O2 sensors because I got a new high flow cat with downpipe. Not sure why that's faulting.
                Ah my apologies.
                Makes it a little more difficult but not impossible.
                A vcds autoscan if you can get one will make it easier.
                Do you know what you were changing before you had the BCM incorrectly coded issue? Just generally? Might make it easier to debug.
                Also you could compare you coding to a similarly specced vehicle reference scan in the Ross tech forums (don't change anything, just try and find one to compare against).
                  Ah my apologies.
                  Thank you for your kindness and swift responses. I can borrow my friends vcds tool for a complete scan and post it here in 2 days.
                  I've changed so many modules that I'm unsure what I could have messed up in 09.
                  I could try and find a similar spec vehicle reference scan too.
                  The O2 Sensor is bugging me though. That's the main cause of my concern.
