How do I post VCDS Output in a Forum Post
  • How do I post VCDS Output in a Forum Post
    Hi All,
    I would like to get some advice on fixing a coding error in my Mk6 GTI and think it would be useful to attach VCDS output. I've looked through the FAQs to see how best to do this but can't find the recommended way to do so.
    Advice on how best to do this would be appreciated.
    Cheers.
    Cut and paste the script from notepad on the laptop is how I would do it.
      Thanks for the response h100vw. I was wondering if there was a way to get around the post character limits but still be able to post the entire VCDS output.
      Tried the embed as Code and as html but neither of these seemed embed the pasted text in a code box as happens on some other forums. Is there a different technique that you like to use here?
        Just cut the part for the unit with the bad coding.
        What's the problem that you have?
          I was going to suggest the code tags, but I haven't tried really long form text in a while....
          From the test below, you do get 10,000 characters, so maybe split it into two if needed? My last log (that I can find) is only 8,697 so would fit, and even something twice as long should be easy to split to two posts.
          Code:
          Monday,29,November,2021,16:15:14:35849
          VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
          VCDS Version: 21.9.0.2 (x64)
          Data version: 20210903 DS330.0
          www.Ross-Tech.com
          VIN: XXXXXXXXXXXXXXXXX   License Plate: MRSHWK
          Mileage: 225580km-140168mi   Repair Order:
          Chassis Type: 7H-VN75 (6N0)
          Scan: 01 02 03 04 08 09 10 15 17 19 25 69
          VIN: XXXXXXXXXXXXXXXXX   Mileage: 225580km-140168miles
          01-Engine -- Status: OK 0000
          02-Auto Trans -- Status: OK 0000
          03-ABS Brakes -- Status: OK 0000
          04-Steering Angle -- Status: OK 0000
          08-Auto HVAC -- Status: Malfunction 0010
          09-Cent. Elect. -- Status: Malfunction 0010
          10-Park/Steer Assist -- Status: OK 0000
          15-Airbags -- Status: OK 0000
          17-Instruments -- Status: OK 0000
          19-CAN Gateway -- Status: OK 0000
          25-Immobilizer -- Status: OK 0000
          69-Trailer -- Status: OK 0000
          Address 01: Engine (J623-CCHA)       Labels:. 03L-906-022-CAA.clb
             Part No SW: 03L 906 022 GF    HW: 03L 907 309 K
             Component: R4 2,0L EDC   H32 9130
             Revision: 26H32---    Serial number: 00000000000000 CVN: C8DA09CF
             Coding: 01254012232400080000
             Shop #: WSC 23117 959 96126
             ASAM Dataset: EV_ECM20TDI01103L906022GF 002008
             ROD: EV_ECM20TDI01103L906019DG.rod
             VCID: 6FE724D2B61105F1A8-803A
             VINID: 9E60AAAAA1D8A9160210400910788D7F80
          No fault code found.
          Readiness: 0 0 0 0 0
          Address 02: Auto Trans (J217)       Labels:. 0BH-927-711.clb
             Part No SW: 0BT 300 045 F    HW: 0BH 927 711 B
             Component: DSG DQ500-7F  H02 0711
             Revision: 00H02V01    CVN: 00CA3CC6
             Coding: 0014
             Shop #: WSC 00000 000 00000
             ASAM Dataset: EV_TCMDQ500021 001001
             ROD: EV_TCMDQ500021_001_VW37.rod
             VCID: 3875DF8E83DF8249B9-806C
          Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
             Part No SW: 7E0 907 379 E    HW: 7E0 907 379 E
             Component: ESP MK25A XT  H43 0103
             Revision: 00H43001
             Coding: 108724AD09A8089924A2907AAA6216
             Shop #: WSC 02756 790 49152
             VCID: 346DEBBE97B7662995-8060
          Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
             Part No SW: 7E5 907 040 H    HW: 7E5 907 040 H
             Component: ClimatronicT5 H10 0101
             Revision: 00002001
             Coding: 0002001102
             Shop #: WSC 02757 790 50316
             ASAM Dataset: EV_ClimatronicT5 A01002
             ROD: EV_ClimaAutoT5Basis.rod
             VCID: 2D5BFEDA7C9D37E1DA-8078
             Slave 1:
             Subsystem 1 - Part No SW: 7E5 907 049 A    HW: 7E5 907 049 A
             Component: Heckbedienung  H10 0101
             Serial number: BHB-0010302100010141
          1 Fault Found:
          9481200 - Refrigerant Pressure
                    B10AB F0 [008] - Too Low
                    Intermittent - Confirmed - Tested Since Memory Clear
                       Freeze Frame:
                              Fault Status: 00000001
                              Fault Priority: 2
                              Fault Frequency: 1
                              Reset counter: 231
                              Mileage: 225439 km
                              Date: 2021.11.29
                              Time: 14:51:36
          Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
             Part No SW: 7H0 937 087 B    HW: 7H0 937 087 B
             Component: BCM T5GP H+4  H46 0207
             Revision: BO046001    Serial number: 0156 044100618
             Coding: A0A0293A0E61240393204000242B8FD40080410F60040000300000000000
             Shop #: WSC 02756 790 00000
             VCID: 336FE8A292B961118C-8066
             Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
             Component: RLS 090210 05  54  0403
             Coding: 03302E
             Subsystem 2 - Part No SW: 7E0 959 801 B    HW: 7E0 959 801 B  Labels: 7E0-959-80X-V1.CLB
             Component: J386__TSG_FT  002 3310
             Serial number: --------------------
             Coding: 010000
             Subsystem 3 - Part No SW: 7E0 959 802 B    HW: 7E0 959 802 B  Labels: 7E0-959-80X-V1.CLB
             Component: J387__TSG_BT  002 3310
             Coding: 000000
             Subsystem 4 - Part No: 7E1 951 171
             Component: DWA-Sensor 00  001 0104
             Coding: 000000
             Subsystem 5 - Part No: 1K0 951 605 C
             Component: LIN BACKUP HO  H05 1501
             Coding: 000000
             Subsystem 6 - Part No: 7E1 951 171
             Coding: 000000
          1 Fault Found:
          03303 - Response Closing Status of Rear Left Door
                      008 - Implausible Signal - Intermittent
                       Freeze Frame:
                              Fault Status: 00101000
                              Fault Priority: 2
                              Fault Frequency: 223
                              Reset counter: 232
                              Mileage: 218891 km
                              Time Indication: 0
                              Date: 2016.03.29
                              Time: 09:10:15
          Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
             Part No SW: 7E0 919 475 A    HW: 7E0 919 475 A
             Component: PARKHILFE 8K  H10 0008
             Revision: --------    Serial number: 32730921101878
             Coding: 010101
             Shop #: WSC 30114 831 1247424
             ASAM Dataset: EV_VW75XParkAssis8K A01003
             ROD: EV_VW75XParkAssis8K_A01.rod
             VCID: 3065E7AE6BAF5A09F1-8064
          Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
             Part No SW: 7E0 959 655     HW: 7E0 959 655
             Component: VW10Airbag02E H05 0011
             Revision: --------    Serial number: 003E4000BAED
             Coding: 000000000000000000000000000000003245
             Shop #: WSC 02754 790 50316
             ASAM Dataset: EV_AirbaVW10BPAVN750 A01001
             ROD: EV_AirbaVW10BPAVN750.rod
             VCID: 73EF28A2DA3921114C-8026
             Crash sensor for side airbag: driver side:
             Serial number: 3495ZRB405B6094IH0NJ
             Front Passenger's Side Airbag Crash Sensor:
             Serial number: 3505ZRB405E70PNC0ORC
             Rear Side Airbag Crash Sensor (on driver's side):
             Serial number: 3515ZRB40556JIHQF9VR
             Passenger side rear thorax airbag crash sensor:
             Serial number: 3525ZRB40576JIHQP8MU
          Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
             Part No SW: 7E0 920 870 A    HW: 7E0 920 870 A
             Component: KOMBI         H16 0111
             Coding: 160F00
             Shop #: WSC 02756 790 50316
             ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04041
             ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
             VCID: 27570CF25E611DB120-8072
          Address 19: CAN Gateway (J533)       Labels:. 6N0-909-901-6R.clb
             Part No SW: 6N0 909 901     HW: 7H0 937 087 B
             Component: GW-K-CAN TP20 0207
             Coding: 042300
             VCID: 70E527AEA32F1A09B1-8024
          Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
             Component: IMMO          H16 0111
             Serial number:
             ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
             ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
          Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
             Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
             Component: Anhaenger     H07 0070
             Revision: 3A001001    Serial number: 00000128849235
             Coding: 0300000100000000
             Shop #: WSC 20117 959 97404
             VCID: 3065E7AE63AF5A09F1-8064
          End-------------------------(Elapsed Time: 03:01)--------------------------
            I'll give the code tags a crack next time. Thanks Hawk.
            Code:
            Like This
