2017 Multivan stud pattern
  • 2017 Multivan stud pattern
    Hi dubbers, which Australian vehicles match the wheel stud pattern & offset for a 2017 Multivan?
    I believe Holden does, but was wondering if any other manufacturers do also.
    I'm looking at purchasing a secondhand set switching up from the standard 16 to 18 inch.
    T6 Multivan should have 5 x 120 bolt circle with 65.1mm centering.
    16" wheels - 6.5J x 16 ET51
    17" wheels - 7J x 17 ET55
    18" wheels - 8 x 18 ET50
    You could try Commodore wheels in 18", Land Rover Discovery up to 2016 18", BMW X3 18" between 2003 to 2018.
    Not exact matches but within 10 +/- off set and center bore.
    Flipper Dog
    Now - T-Roc R, Audi Q5
      Amarok 18" wheels would be your best bet. Not only would they clear the brakes, they are also correctly load rated and have the same centre bore and stud pattern.
      Only LR Discoverry and BMW X5 wheels are similarly load rated (Mutlivan is a heavy car), but center bore is wrong, so you need hub centric rings to make the wheels fit assuming offset is OK.
        I'm happy with the suggestions here, thanks a lot.
          At what diameter increase do you think the speedo would need to be re-calibrated?
          eg. 18" or 20"?
            eg. 18" or 20"?
            Provided you fit the correct sized tyres, there should be no need to re-calibrate the speedo.
            Have a look here 215/65-R16 vs 235/50-R18 Tire Comparison - Tire Size Calculator | Tacoma World
            Std 125/65/16s are similar in circumference to a 235/50/18.
            When you show up at a tyre place, they will be able to show you what tyres you can fit to get the same circumference on the 18" wheels.
              Ok that's actually bugger all difference, I never knew the height profile made such a difference thanks
