A family friend gave us a DGAV Weber, has some grease/grime build up on the outside and want to get it all cleaned it up. Any ideas what is best cleaner product or should I just clean with a rag and petrol ??
Clean a weber?
Ummm, Carby cleaner?
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
If you're stripping it you can use HOT water and 2 scoops of washing powder in a bucket. Let it soak for a couple of mins then scrub with a tooth brush. Finally rinse off with cold water.
Originally posted by Peter Jones View PostUmmm, Carby cleaner?
carb cleaner and tooth brush should do a decent job.
Originally posted by Preen59 View PostIf you're stripping it you can use HOT water and 2 scoops of washing powder in a bucket. Let it soak for a couple of mins then scrub with a tooth brush. Finally rinse off with cold water.
Got a can of Carby Cleaner, wire brushes, rags and scotch pad ready
Might snap a few pics, but this is my first time doing it so maybe wrong<space for rent>
