Does the bridge go over moving water? Just thinking hydroelectric power!
Adam
2012 Subaru WRX STi Spec-R in "Lightening Red" because red cars are the fastest!! Previously - 2007 EOS 2.0 TFSI Indium Grey ~ Photos Here
2002 Bora V5
You need to re-think the 60w globes and start thinking LEDs or compact fluorescents.
Say you build a 24 volt system and it's got to deliver 480watts all night long ~12 hrs. That means it's got to be able to support a drain of 20 amps and it's also got to be able to recharge at 20 amps assuming equally long days and nights.
A Panel array that can deliver 20 amps is around the $3500 mark. Based on Jaycar pricing.
You'd be better off just sticking these on poles.
or the motion activated type
They'll run you about $100 a pop though.
Both of the above available at Jaycar.
On the plus side, they're self contained and require no cables or anything and run for about 10 hours.
Realistically though get a quote from a sparky to run out a mains powered setup it'll work better and cost a lot less to run.
Solar never really pays off 'cos mains power is so cheap by comparison.
Mate thank you so much, great ideas. At $100 a pop thats only $800. Surely a kit with regulator, inverter, solar array, lights, wiring and headfark would be a lot more?
And power isn't cheap. Our power bill alone is $2,500 a quarter and getting worse.
If you've got access to mains power it's always cheaper to buy the electricity ready made. It's very expensive to make your own power.
Some of the better garden lighting systems are pretty good these days, they could be adapted to run off solar or are pretty efficient run via a transformer off the mains.
With that type of bill, it would be worth getting somebody to review where you might be able to save some money - change of lighting systems; switch some systems to off-peak etc.
carandimage The place where Off-Topic is On-Topic I used to think I was anal-retentive until I started getting involved in car forums
A good electrician should be able to offer some suggestions, but try your power supplier first they're increasingly helpful in reducing power consumption.
if you're paying that much per quarter for energy, i'd seriously look at getting a decent solar set up for the house!
There are systems that are connected to the mains that recharge excess power that you're creating, and get paid for. and if you aren't making enough, you just use power of the mains as per usual. This could save you a fair bit in electricty bills, and (depending on size of the set up) could pay itself off after 5-10 years, then it's 'free' energy.
Sorry if that's a bit jumbled, i havn't gone into detail, but I'm sure you get the jist of it.
Pete Jones is right though, if it's only for lighting a driveway (and 8 lights) a stand alone power system isn't going to be economically viable. Those jay car ones look pretty nifty actually, and 8 of them would be truck loads cheaper than a decent solar set up, imo.
If Aussie Solar will come to your area, they can do a basic 1.5kW PV setup for ~$1300. Doesn't help with your driveway lights but it would knock $90 off your bills most months ($25 off the bill & $65 for your gross feed).
If you opt to setup an isolated system, i wouldn't be going the 240V route unless you have to.
LEDs run off DC,
Solar panels generate DC,
using an inverter to convert to AC then a rectifier to convert back to DC is going to waste 20-30% in each conversion...
i would buy a set of forklift batteries, and use solar panels to charge them.
If you use them to power the LED lights off a light sensor, they should last days without charging, which should help with overcast periods and short days in winter
2010 Golf R - 3dr - Manual - Rising Blue - MDI - SatNav - Milltek TBE
I work at Jaycar and we help customers do this kindo stuff all the time. Its easy as p!ss but it wont be cheap.
To keep the cost of the solar panels down you should make use of LEDs. We have LED strips that are super bright and are about $30 for a 50cm strip (non water proof) but you can make the prity water proof using clear heatshrink which we also carry, ask for a demo at your local store, you will be suprized how bright they are. Other than that there are heeps of LED options and a few neon/fluro options too. LEDs will consume the least amount energy.
It all depends on how many lights you want but i cant imagine your drive way needing more than a 120watt solar panel. They are about $500-600, come with 1year warrenty and a 12year limited warrenty IIRC. You will need a charge contorler, you can get a simple one for $30 or a digital one with a read out and memory for $170. All our solar panels are 12v appart from the largest one which is 24v.
On top of that you will need batteries to store the power, our SLAs range from ~2ah up to 100ah in 12v. You can also use a car battery but again it depends on how many lights you have. Keep in mind the charge rate of the solar panel.
We also have wind generators that are about the same price and specs as solar panels but obviously dont require the sun to create charge.
Just pop down to your nearest jaycar store and have a chat with them, they will be more than happy to help you. We have just about everything you need for this project.
I shoulda said this first!
The Jay-car guys in our area are always more than happy to assist customers and give demos!
Great service/knowlege and a massive range. Jaycar FTW
MK2 - *Insert list of dealer purchased extra's/standard features here* 80 series - The MK2's BIG, Sooty, polar opposite... HAHAHA
