L.E.D festoon number plate bulb?
  • L.E.D festoon number plate bulb?
    Any ideas before I go looking into where I can get replacement No plate lamp globes for nice crisp white LED units, Think you can get a festoon replacement globe for the original holders? (MK4 golf)...............VW..........
    Are you looking for something like this? - http://www.ngmotorsport.com/shop/products/48.php & http://www.ngmotorsport.com/shop/products/47.php
    Wait, never mind, was half-awake so wasn't reading properly lol.
    I've bought some LED lights for different fitments and such from http://autolumination.com/ before. You could try them out if SuperCheap/Repco/Autobarn don't have what you want.
    Present: Mk3 Golf variant.
      thanks, think I will have a walk around repco this arvo see what they got, .......VW..
        Just be sure to get the wires and socket lined up with aftermarket LEDs. I'm having a heck of a time with one in my stoplights, and it would have to be the one behind my built in sub box, where access in difficult. Quite annoying! Then again on a number plate light that might be a bonus!
          I got mine from Autobarn.
          Cheers,
          Trent
            I upgraded my number plate lights to a crisp white about a year and a half ago. I brought mine from kmart and I have never had a problem with them, and they were a he'll of a lot cheaper than everywhere else I looked. I get slot of people commenting on how good they look too.
            White Scirocco R
            White MK3 Golf 2dr
            White Caddy (Work Van)
              Are they LED?
                Crisp white LED's
                Yes there are 3 led in each globe, here are some pictures to show you the difference between the standard globes and the new led's.
                Hope these help you,
                White Scirocco R
                White MK3 Golf 2dr
                  ehhh....mine went out after half a year. some interior ones start flickering as well. will go measure the voltage tomorrow and figure out which resistor to splice in
                  '01 VW Bora V6 4motion - gone
                  17x8 TSW Hockenheims ~ TyrolSport Brake Upgrade ~ SMF + Stage 1 Clutch ~ 42DD Shifter Linkages ~ FK Coilovers
                    Bright LEDs Xenon White
                    I've have these fitted on my Mk4 Golf GTI
                    with 6 SMD LEDs on each Festoon Bulb they are really bright!
                    im more than happy with them. Had no troubles installing them exchange them over and done they shine onto the road quite well too
                    Hope this helps, i highly recommend these
                    Jono
                      I had a look in Kmart yesturday, couldnt see them.............
                        I'm pretty sure they were in a blue packet, you can also test them in the packet before you buy them as they have a little battery set up inside, next time I'm at kmart I will have a look and take a photo for you and look how much they are, worse case if you can't find them I'm more than happy to pick some up for you and chuck them in the post for you
                        White Scirocco R
                        White MK3 Golf 2dr
                          Thanks mate, I think they stock different stuff in different stores depending on how big they are. I saw what you mean, the packet with the tester on so you could light up the bulb but they were the push in "501" side light "park" bulbs for the front, didnt find any festoon there. Autobarn sell them but dont do white, just the illegal blue and red ones! If you can find a couple that would be great, let me know how much they are. ...........VW......
                            If you really want to do things properly then 42 Draft Designs is your answer.
                            Cheers,
                            Trent
                              autbarnnns man, ill hook u up =]
