Originally posted by Manaz
View Post
In the definition of lowering in the actual government produced document there is no mention of the no more than 50mm change either way rule applying to lowered vehicles......only that they must not be lower than 100mm.
The no more than 50mm change rule applies entirely to raised vehicles and applies to the gap between axle and guard...
ADR compliance is done for many versions of VWs at different suspension heights...so if you've a stock Golf and you want to run at the same low height as an R32 then that is fine....but you still need a engineers certificate/blue slip to do it in NSW......and what on Earth is the problem with that?
Certification is just another form filling exercise and only needs to happen once. Sure it might cost but you'll have just paid through the nose for some ridiculously short springs anyway.....what's another $200!!
