Anyone have a good understanding of the Air Con a T4 Caravelle?
Hit a kangaroo (that's life in Oz) and ended up have a bunch of panel work to the nose and a new radiator and A/C condenser. Following the repair I noted a chattering that turned out to be coming from the hi/lo pressure switch. Before it exploded. After replacing this switch and regassing it was noted that the fans were not switching on in response to either the A/C being switched on, or increasing engine temperature (obstructed airflow through radiator also confirmed integrity of radiator fan switch)
Long and complicated story. (Mis??)diagnosed as a faulty fan relay. Different VW specialist identified and replaced failed/damaged fan resistor/s. All good now ... albeit via an expensive failure of the rear evaporator unit. Over $1000 after regassing ... ouch!!
I'm struggling to understand how the system was unable to protect itself when the fans failed. Pressure seems to have gone ridiculously high, destroying the hi/lo pressure switch (it exploded) and I'm wondering if it may also have contributed to the leak in the rear. How and where does the pressure build? And why didn't the hi/lo pressure switch stop it?
I want to put a case to my insurer that the whole lot is their baby! If I can't find a satisfactory explanation to the contrary.
Thanks !!
Thanks !!
