Hello folks
Our company has a 2010 T5 Transporter that has a problem with flickering instrument/switch panel backlighting. On occasions the instrument cluster backlighting will also flicker.
I've checked the fuse panels and all seem OK. The loom is securely fitted to the headlight switch, as too the brightness control - although the brightness control has no effect.
I removed the brightness control hoping it might have been just a dirty variable resistor but it looks like there's a chip inside too. Are the backlights actually LED's and the brightness controlled by pulse width modulation?
Not having a wiring diagram I probed the brightness 3 pin connector and found the +12v then bridged it to one of the other pins; that brings on some of the backlights, not all, but at least they're not flickering.
Has anyone had similar problems? If so I'd appreciate and advice/suggestions (and even a wiring diagram
TIA
TIA
