Replacement Battery for 2012 T5.1
  • Replacement Battery for 2012 T5.1
    Looks like the original battery is in the way out in my van.
    What replacements have people been putting in these vans here in Aus?
    How is 5 years for the original these days? (I had 8 years from the original in an '82 T3.)
    Thanks folks.
    Sent from my SM-G900I using Tapatalk
    2012 132kw T5.1 TDI DSG 4Motion LWB Transporter, locking rear diff. Macron Campervan conversion. ECB bullbar. Milford towbar and rear light protector. Seikel Desert HD 30mm lift kit.
    After top grade Varta, the BOSCH S5 is a good choice. You can also fit a bigger battery there.
      Thanks Transporter.
      (I put a compressor next to the battery so there is no room at all for a larger battery. Didn't even THINK of the possibility at the time. )
        In 2013 I replaced my original 2010 battery with this on the advice of my auto elec - Platinum Power 2000 N55HMF 550CCA 100RC for $143
        No problems 3-1/2 years later
        __________________________________________________ __________________________
        VW Transporter T5 MY10 Van M 6spd 2.0DT 103kw White. Long wheel base. Standard roof?
          Hmm, bit on a smaller side. There is a reason why diesel vehicles have a battery with a higher CCA capacity.
            Maybe I need to be looking for a new auto electrician as well
            Had hoped I didn't need to double check a paid professional.
            Haven't noticed any problems since then. What could the effects of this be?
              Cars like that need AGM batteries and buying one with higher CCA will ensure it will last longer. For your 2012 T5 these 2 are good, 730 and 760CCA. The higher spec one sells at the moment for $199 at SuperCheapAuto, but confirm again as well as the size too.
              MY15 TIGUAN 130TDI R-LINE - Pepper Grey, Panoramic Sunroof
                Thanks for that.
                  Thanks. Was at Battery world a day or so back and they told me Century batteries are actually re badged Varta batteries. That should be a positive.
                  On the other hand, with batteries, with every positive you always get a negative😂.
                    An optimist would say With every negative there must be a positive at the other end.
                      Enough esoterica. How about we get down to earth again?
                        Mine is over 5 years old now and on the way out.
                        Doesn't seem to be a Varta replacement in Australia.
                        Plenty in Germany, it seems!
                        2018 Crafter Runner
                        2012 T5.1 6sp manual.
                        2024 Crafter Auto
                          eBay has sellers in Australia. Have a look
                          Sent from my HTC_PN071 using Tapatalk
