Hey guys, I just wanted to start a thread on the wiring of the T5's. See if we could get some brains together to sort out a few things.
My main question is, are all the wiring looms for the T5's the same whether the accesories are fitted or not. I got told by a friend that all the wiring is there from factory across all t5 models. So for example if you had a standard t5 van and you wanted to install the vw sat nav from a multivan/caravelle you could just plug it in or if you wanted to install fog lights from a multivan/caravelle you just install the lights and get the correct headlight switch. In a nutshell he said that the wiring is there even if it is not being used. Can anyone confirm or deny this?
