Hi All
I've been reading a bit but I'm not in any better position.
I've got a 2005 T5 2.5TDI 4 motion and the engine no. starts with AXE. I've got a blocked injector, and was trying to hunt down somewhere that might be a little cheaper than the $1000 each they cost here in Oz. As the motor has 260K on it I think it is time to do all the injectors, and so am just trying to get the cost down a bit.
Reading all over the net and seeing what's available I can see injectors for AXD, AXC, BNZ, BRD engines, etc etc, but none for AXE. Are any interchangeable? Why are AXE not so readily available?
Anyone know of anyone that does recond injectors? I understand some might frown on them but economics dictates what can be done sometimes.
Regards
Daniel
I've got a 2005 T5 2.5TDI 4 motion and the engine no. starts with AXE. I've got a blocked injector, and was trying to hunt down somewhere that might be a little cheaper than the $1000 each they cost here in Oz. As the motor has 260K on it I think it is time to do all the injectors, and so am just trying to get the cost down a bit. Reading all over the net and seeing what's available I can see injectors for AXD, AXC, BNZ, BRD engines, etc etc, but none for AXE. Are any interchangeable? Why are AXE not so readily available?
Regards
Daniel
