any body know where to find vagcom codes and explanations for t5 128kw vans as dealer doesn't know anything
vagcom
On a T5 the dealer will be using 5051 or 5052 and will be using Guided fault finding which will draw the code and guide them through the fault diagnosis track, it will also work through a fault table. So there isnt any excuses for not knowing what a code is. Thats a lazy excuse mann:Alba European
The capacity to have auto dipping of passenger side mirror when selecting reverse seems to be a hit-or-miss thing on VWs. Lots can't do itOriginally posted by baldy View Postnot after a fault code i was after codes to change locking an unlocking ie one press two press etc . in being fair they know this one but what i was after mainly is getting the left hand mirror to dip when it is put into reverse.
thanks
(regardless of whether you know the codes or not). May need to have memory seats on some vehicles ? If you do a search on various VW internet forums it is a topic that comes up regularly (particularly for Golfs, but unfortunately IIRC T5 electronics are more like Polos).
Good luck, and let us know how you get on.2017 MY18 Golf R 7.5 Wolfsburg wagon (boring white) delivered 21 Sep 2017, 2008 Octavia vRS wagon 2.0 TFSI 6M (bright yellow), 2006 T5 Transporter van 2.5 TDI 6M (gone but not forgotten).
rear sensors needed for mirror dipping
hi baldy
from my roamings in this forum, i think you need rear parking sensors to have the mirror dipping feature.. do a search on 'mirror' and you'll be able to read along like i did
MY12 Golf 118 TSI, manual.
Again they use 5051 or 52 and coding convenience electrics or body electrics now also gets done through guided fault finding the workshop manual will not give you a code, thats why they cant tell you. The program is in 5051 and its a walk through program.
CheersAlba European
