i think my steering rack is broken
  • i think my steering rack is broken
    hey guys after my weekend blast down to vic, i got to about 20ks from my house and slowed down to 60 and the steering started to get a killer wobble, i slowed down and checked it and i could find anything obvious, drove again and it does it up to 60ks then it stops once above that speed. but comes back when you slow down again. the next day i jaked up the car and the wheel bearings seem tight as do the wheels and the subframe. when i wiggle the wheel on the horozontal axis it seems there is abit on free play in the steering rack. i know that they can have racks wear out . does this sound like a typical case ? the tie rods dont seem to be the problem. any help would be great as ive got no cars to drive
    cheers brenton
    MK1 4door
    MK2VR6
    MK3VR6
    Transporter
    1st place, stock MK3VR6. Vw nationals 07
    2nd place, mod MK2VR6. Vw nationals 09
    and untold wrecks
    That's the genuine VW speed limiter for suburban areas kicking in
    Just a thought,I had similar on a Mk1 Golf before one of the CV's let go
    Steve
    04 T5
      Yeah might be driveshaft CV related. I haven't heard of the tie rods coming out of the rack.
      The worst that I have seen is mega bad leaks.
      Sure you've not lost a big balance weight?
      Have you tried it on different roads, might be tarmac related? Like when you think a bearing has gone but it's just that you drove onto some different tarmac and the road noise changes.
        The steering arm knuckles are bad for weariing on them. Had 1 wind out on a NSW ambulance. You buy the arms complete mate ive posted the part numbers on here before, let me check them again for you. ill post the numbers later. They are very common on T4.
        CHeers
        Alba European
          yeah its not tarmac related, ive driven on different types same prob, could be a wheel weight but wouldnt that get worst with increased speed? cv joints i dont notice any noises forward or reverse. when the van is jacked up there is play in the steering but the tierods seem to be tight, and the movement it back in the rack ?
          cheers brenton
          MK1 4door
          MK2VR6
          MK3VR6
          Transporter
          and untold wrecks
            The play you will find is in the knuckles right at the rack, get someone to rock the steering and feel inside the bellows. They are very common for play there mate.
            See how you go
            I dont doubt that the rack might have play too but just check them knuckles.
            Cheers mate. swap your front wheels with the back too and see if it gets better that would rule ot your wheel balance mate
            CHeers
            Alba European
              alrite so how do you fix the play at the knuckles ? replace the arms is it a hard job, ive changed the whole subframe already not looking forward to taking it out again can they be replaced with the rack in the subframe still ?
              cheers brenton
              MK1 4door
              MK2VR6
              MK3VR6
              Transporter
              and untold wrecks
                Yes they can champ. A 38mm crows foot is the ticket. I have used stilsons in the past too. But to answer the question yes you can no worries.,done heaps probably done 50 % of the NSW ambulances.
                CHeers
                Alba European
                  I randomly scored some new genuine knuckles the other day too man, or rip the ones out of your scrap rack you have up there.
                    nice finally some good news in relation to my van haha.
                    so they can be changed, now i just have to have a look and get info on how to do it. so really i should change the tierods aswell while im at it.
                    cheers guys i was on a bit of a downer again with the van lol
                    cheers brenton
                    MK1 4door
                    MK2VR6
                    MK3VR6
                    Transporter
                    and untold wrecks
                      Be on here tomorrow and ill post it step by step. Tie rod complete with knuckles mate.
                      Alba European
                        thanks mate you have been a great help thru out all my van trials lol
                        cheers brenton
                        MK1 4door
                        MK2VR6
                        MK3VR6
                        Transporter
                        and untold wrecks
                          also is it safe to drive if that is the problem ? ive already had a lower control arm fail, its not fun and the van is to big to tow home lol. jimmy are the parts from a manual rack the same as a power steering rack as ive got a old manual rack kicking around ? and what do the new arms normally cost ?
                          cheers brenton
                          MK1 4door
                          MK2VR6
                          MK3VR6
                          Transporter
                          and untold wrecks
                            hey guys problem sloved, always check your wheel weights figured that out after putting on new rack ends lol. wheels weights can dramatically wobble the steering , even at low speed. I was experencing massive wobble in the steering.
                            cheers brenton
                            MK1 4door
                            MK2VR6
                            MK3VR6
                            Transporter
                            and untold wrecks
