I'm in the process of replacing the cam & injection pump belts on my 2.5 TDI (ACV).
I know the main crank bolt is supposed to be 160nm plus 180 degrees but I'm having trouble finding the torque settings for the other bolts, cam pulleys, tensioners/idlers.
I also need the torque settings for the camshaft journal caps as I had to remove the camshaft in order to have the vacuum pump eccentric reground due to some wear. It was ground 11 thou so there should still be enough preload on the vacuum pump pushrod to avoid any rattling. - TIA
