Hello all,
I've got a VW T5 2.5L tdi 2009 that I service myself according to the service schedule. I've noticed that whenever I do an oil + oil filter change the oil gets fairly black as soon as I pour in the new oil and check for the oil level on the dip stick. Is this normal for a diesel engine?
Basically, what I do when I change the engine oil I will:
1, Take van around the block to heat up the oil a bit.
2, Drain all oil out until oil drips extremely slowly.
3, Remove oil filter
4, Replug sump and poor in 500-1L of clean new oil
5, Remove sump and flush completely again
6, Fit new oil filter and poor in the new oil
I don't have a vacuum tool to extract the oil in the oil filter housing, is this where all the dirty oil is getting caught up?
Or have I missed something? Would it be safe to crank the engine briefly between step 4-5 to get the oil moving a bit?
Oil used: Mobil1 ESP 5W30
Any tips would be great!
