It’s been discussed in our forum that the latest T5 has no fuse box assignment notes in the owner’s manual or on the fuse boxes covers. Here is some info for now (more will come later), I’d like, if someone could take the pictures of their fuse boxes so we could have some “real life” examples.
Please use this thread for comments. http://www.vwwatercooled.org.au/foru...dex-64025.html
Code:
[img]https://www.vwwatercooled.com/images/imported/2011/10/Fuse252520carrier252520locationpng-1.jpg[/img] [U][B]Fuses location and meaning[/B][/U] No. Current Flow Diagram designation/Nominal Function/component/Terminal value (not a real value unless you have the wiring diagram, so I removed the information from the content) [img]https://www.vwwatercooled.com/images/imported/2011/10/T52fuseboxFJPG-1.jpg[/img] 1-Fuse 1 on fuse holder F - 15 A 2-Fuse 2 on fuse holder F - 3 A 3-Fuse 3 on fuse holder F - 15 A 4-Fuse 4 on fuse holder F - 15 A 5-Fuse 5 on fuse holder F - 5 A 6-Fuse 6 on fuse holder F - 25 A 7-Fuse 7 on fuse holder F - 30 A -12 V socket 8-Fuse 8 on fuse holder F - 25 A- Heater control unit, remote control receiver for auxiliary heating 9-Fuse 9 on fuse holder F - 25 A- Fresh air blower isolation relay, Voice amplification control unit Rear blower regulation motor 10-Fuse 10 on fuse holder F -3 A or 15 A-Auxiliary heater relay [COLOR="#FF0000"]11-Fuse 11 on fuse holder F -15 A -[B]Cigarette lighter[/B][/COLOR] 12-Fuse 12 on fuse holder F -15 A 13-Fuse 13 on fuse holder F -SF13- -Vacant 14-Fuse 14 on fuse holder F -SF14- -Vacant 15-Fuse 15 on fuse holder F -SF15- -Vacant 16-Fuse 16 on fuse holder F -SF16- -Vacant 17-Fuse 17 on fuse holder F -SF17- -Vacant 18-Fuse 18 on fuse holder F -SF18- -Vacant 19-Fuse 19 on fuse holder F -SF19- -Vacant 20-Fuse 20 on fuse holder F -SF20- -Vacant 21-Fuse 21 on fuse holder F -SF21- -Vacant [COLOR="#FF0000"]22-Fuse 22 on fuse holder F - 15 A-[B]12 V socket 2[/B] 23-Fuse 23 on fuse holder F - 15 A-[B]12 V socket 3[/B] [/COLOR] 24-Fuse 24 on fuse holder F - 10 A 15A only models with auxiliary coolant heater 25-Fuse 25 on fuse holder F - 15 A-Trailer detector control unit -J345-30 26-Fuse 26 on fuse holder F - 20 A-Trailer detector control unit -J345-30 27-Fuse 27 on fuse holder F - 20 A-Trailer detector control unit -J345-30 28-Fuse 28 on fuse holder F – 7.5 A-Reversing camera system control unit -J772-30a 29-Fuse 29 on fuse holder F -SF29- -Vacant 30-Fuse 30 on fuse holder F - 5 A-Voice amplification control unit -J656-30 31-Fuse 31 on fuse holder F -SF31- -Vacant 32-Fuse 32 on fuse holder F -SF32- -Vacant 33-Fuse 33 on fuse holder F - 15 A-Driver seat lumbar support adjustment 30 switch 34-Fuse 34 on fuse holder F - 40 A - Right sliding door control unit -J731- 35-Fuse 35 on fuse holder F - 80 A-Battery isolation relay -J7-30 36-Fuse 36 on fuse holder F -SF36-40 A-17-pin connector
