Hi,
I have a problem with the passenger side door electric window switch and need to access the connections. I have read that the switch connections can corrode.
Do I need to remove the whole door panel or will the switch panel pop out when pried with a screw driver? The same as other items on the dash?
I also need to remove a rear door panel on a T5 Dual cab are the plastic pins holding the panel screwed off or pried open?
