MANN Provant (Blow by Oil/Air Separator)
  • MANN Provant (Blow by Oil/Air Separator)
    I have read a fair bit about the use of one of these oil separators for continued life of the DPF. Does anyone make a kit that can be purchased to enable fitting very easy.
    Could anyone who has removed their DPF send me a PM to discuss, please.
    Shifter
    Sadie - 08 VW Dual Cab T5 Transporter 4 Motion (128kW)
    Working on it, but given how much space you have in the transporter engine bay, fitting will be a breeze. I can help, but closer to you ( cheaper postage ) would be the universal kit from my mates at Western filters, but I reckon you'd need a bit more hose. Normal 3/4" rubber heater hose will do, but this silicon stuff they supply and I recommend doesn't break down due to the oil.
    Air Filters, Oil Filters, Fuel Filters & Filter Cleaning Services - Western Filters offers a range of Filter products for comprehensive coverage for on-highway, off-highway, construction, agricultural, industrial, genset, lift trucks and marine equip
    DPF's. Gav ( h100vw ) at Custom Code has the only working DPF delete tune I know of, but that is mainly for the GT TDI with the Siemens ECU. Unsure of other fitments. It's easy enough to replace the DPF with a pipe which includes the sensors, but turning off the regeneration cycle is the trick. Shoot Parso Rex an e-mail, I know he can do all manner of wonderous things. Realise though, that if the EPA or whatever they are called nab you, it's a major, major fine.
      Greg,
      Thanks for the info mate, good stuff.
      Shifter
