vw t4 mushroom bolts???
  • vw t4 mushroom bolts???
    hi anyone know where to buy or have any mushroom bolts for a genuine t4 middle row seat, cheers.
    mk4 the mods begin for round 2 hahahha
    Try Universal Fasteners. Also you can try contacting GolfLoon he might have some secondhand.
    Performance Tunes from $850
    Wrecking RS OCTAVIA 2 Link
      they are a very odd item been trying to even find a part number for them, good system tho if i can find the mushroom bolts.
        all good please delete this thread i found them...
          Would you share where did you get them from?
            mates in the right places.
              Can i ask what you bolted these into?
              Are they for a T4 Caravelle
              If not i hope you used the spreader plates on the captive nuts under the van?
              If you dont use spreader plates the seat might rip out of the floor in a crash.
              Hope this info might save some one.
              Rob
                thanks i talked to a guy in the uk who does the genuine seats, he told me that i needed the captive nuts aswell so im getting the bolts first and then ill get the captive nuts for under the van, thanks there are a few styles on nuts/base plates so ill get under the van to see what it looks like when it goes throught the van floor.
                going in my t4 wich had a bed seat but i got the genuine middle row the 2seater and single seater so i can take them out easy for putting my bikes and stuff in.
                  Hi, Still got the bed seai? Is it for sale?
                  BobR
                    BobR
                    yeah i mght sell it not sure yet not even sure what to ask for it, know they are not a cheap item.
                      Sent you a PM
                        One of the nuts is a pain in the arse to get on the bolt.
                        Its the one nearest the sliding door.
                        The best way to fit it is to put the nut on a spanner and tape it on so it does not fall into the box section.
                        Once tight you can pull the spanner and rip the tape.
                        The spanner has to go in through a hole and at an angle.
                        You dont have to make the nuts captive but if you remove the bolts then they will need to make them captive.
                        Hope it helps Rob
