Looks like it is the water pump, as there is some 'milkiness' under the oil cap now.
I have been quoted $1000 at a VW specialist to have this repaired with an SKF water pump and using my own oil and coolant (purchased a while ago).
Is this reasonable?
I'm not sure if I have enough confidence to do this job myself, even though I am a DIYer.
In saying so, if I can do the job for under $500, then I would consider spending time to do it!
So, where would you recommend purchasing a water pump from, and what is the most reliable brand?
A special tool was also mentioned. Where can I get this?
Thanks again in advance for any advice.
Is this reasonable?
