Hi fellas, my AC is doing something strange when on Auto control. Normally I set the desired temp and let the system take care of the rest. At the last service they did not have the filter element in stock so the left it out and week later when I had time I dropped back in and they installed it. All was good! About a week after that It was a warm day (32c) got in the van and there was a strange noise coming from below the dash on passenger side., sounded like the fan. Then I could smell an electrical burning smell..... it only lasted for a few seconds but was there.
Since then the AC system has been playing up when in Auto mode. It will start and run for a few minutes then the fan drops to nothing even though the display shows it on full speed. I switch it off for a few minutes and sometimes it works normally and other times it does not. Now here is the strangest part, if I just run it in full manual mode it works perfectly! If I switch it over to auto it some times works or it shuts down.
I dropped into my mechanic , explained what was happening so he connected it up the VW diagnostic computer and scanned it. Sure enough there was an error code! It basically says climate control. He reset the fault and lets the computer run another full test and its all clear. He then does the same again with the engine running and the AC on.... works perfectly again in auto mode.
I set of again and all was good. Stopped at the hardware store, came out 1 hour later and it would not work.
Shut it of, let it sit for a few minute as I drove with the windows down. Then started in manual mode...and it worked again. Only other thing is it seems to happen on warm/hot days.....when you need AC the most.
So..... has anyone else had something like this happen? Any suggestions on what to look for or check? I get the feeling its a sensor the controls the Auto mode and thats why the AC still works in manual.
2005 T5 Multivan.
2005 T5 Multivan.
