Over boost fault
    Hmmm should I be worried if my mechanic takes to my engine with an angle grinder that big?
    Thanks for all the info fellas!
    I was thinking it would be so much easier to just spray something in there to clean it out so I did a quick search and found this product.
    http://www.innotecworld.com/c-1064-turbo-clean-set.aspx Not sure if you can buy it here or not?
    Is there any other way of cleaning it with taking the entire turbo off?
    2014 T5.1 Multivan Tuned by Pendle Performance Australia
      I haven't read of any other effective way if it is truly jammed.
        Just found this thread....
        2000 Golf, 118k, 5 spd, 48 mpg - no mods. New vacuum lines, new timing belt kit, no fault codes (VAG COM), no problems with N75 (nkda), clean intake manifold (EGR too), clean snow screen, new fuel filter, new transmission fluid (Redline MTF), clean MAF, timing in the middle of the upper portion...
          I have been doing a bit more research on this. I know a bloke who used to be an interstate truck driver for 25 years. His recommendation is add a VERY small (cap full) of petrol to a tank full of diesel occasionally to kill the algae that can grow in the tank and also clean out the fuel system.
          He also suggested steam cleaning the combustion chamber and exhaust manifolds etc by taking the air filter off, holding the revs high on a running engine and trickle/mist 0.5lts of water very very slowly into the air intake. The idea is to create steam that removes all the carbon but not in quantities that will damage the engine. He also said that when doing this make sure the engine and exhaust is up to operating temperature and that the exhaust is aimed away from anything as the black muck that gets blown out is filthy.
          Any thoughts?
            Water down the intake study.
              Any thoughts?
              I'd be very reluctant to even try the water in the inlet thing on my TDI for fear it would clog up the (very expensive) DPF. If you had a straight through exhaust it might do something (but not sure if that something would be good or bad).
              Certainly if you gave it too much water at once there is a very real danger of getting hydraulic lock (diesel combustion chamber volumes are pretty small at tdc).
              With a VW TDI you are more likely to have problems on the intake side from oil and EGR gunk, and water won't shift either of those.
                I dont have a DPF on mine. The trick is to keep the revs very high and just trickle/mist water in. I was hoping it may help clean the variable vanes on the turbo.
                  The water may just sit around in all the pipes and intercooler. It has to go a long way from the air intake, through the inlet side of the turbo, through the intercooler and then into the inlet manifold before it actually gets into the engine. I doubt much water would actually get to the engine at all (unless you devise a way to deliver it directly into the intake manifold).
                  The technique may be OK for a non-turbo diesel, but TDIs are a bit more complex.
                  If you do it to yours please let us know how it goes (and what difference it makes to performance and economy).
                    Hmmmm maybe I should do it at the start of a long trip that way there will be plenty of time for it all to be sucked through ?
                      Personally, I wouldn't do it all for the perceived benefits. Very expensive if the engine locks solid and would not be easy to explain to an insurance company if there was no a flood in sight!
                      Diesels of any kind do not cope with sucking in water. They just seize and very seize very quickly.
                      Cheers,
                      Scott
