VW TRANSPORTER T5 128kW R5 AXE Engine
Which engine oil to use?
For all up to and include 6/2006
It must be VW506.01 APPROVED.
LiquiMoly SYNTHOIL LONGTIME PLUS 0W-30
Ravenol WIV SAE 0W-30
Fuchs TITAN SUPERSYN LL PLUS 0W-30
From 7/2006 use VW507/00 5W30 approved oil.
Sump capacity incl. oil filter .................................................. 7.4L
Tyre Pressure front .................................................. ....... 50PSI when fully loaded (max. pressure)
Tyre Pressure rear .................................................. ........ 50PSI when fully loaded (max. pressure)
Wheel bolts Torque .................................................. ......... 180 Nm
Tyre size .................................................. .....................235/55/17 (O.D. 692mm)
Tyre size.............................................. ..........................215/16/17 108/109
Tyre size .................................................. .....................215/65/16
16”Tyres discussion ........ Link to thread
17”Tyres discussion .........Link to thread
Battery .................................................. .......................12V/80Ah 380A DIN, 640A EN/SAE
SERVICING PARTS / FILLING CAPACITIES
Oil Filter……………………………………………………......................... .... VW P/N 071 115 562 C (Purflux L267A) (Mann HU719/7) (Mahle OX 188 D)
Air Filter………………………………………………….......................... ..... VW P/N 7H0129620A or Mahle LX864
Fuel Filter………………………………………………….......................... ... VW P/N 7HO 127 401B or Mahle KL 229/4
Coolant VW G12+…………………………………………………………................ 7.0L
Automatic TransmissionVW p/n G 055 025 …………………………..... 7.0L
Gear oil………………………………………………………………….................... 2.7L 70W75
Transfer case oil……………………………………………………….................1.2L G052145A (TOTAL Trans. Dual 9 FE90 75W90)
Haldex Oil VAG 055 175A…………………………………….....................1.1L
Haldex Oil Filter……………………………………………………….................. 02D 598 574
Diff Oil……………………………………………………………………….................. 1.2L (SAE 75W-90 API GL-5)
Power Steering Fluid G002000…………………………………............... 0.7L - 0.9L
Brake Pads front OEM ATE 13.0460-7240.2.............................Min TH 2 mm
Brake Pads rear VW p/n 7HO 698451 OEM ATE 602882..............Min TH 2 mm
Brake disc front
Diameter: 308mm Vented
Brake disc thickness: 29.5mm
Minimum thickness: 28.5mm (17"wheels /2E4)
Height: 55mm
Centering diameter: 65mm
Inner diameter: 154.6mm
Brake disc rear OEM ATE 24.0112-0169.1
Diameter: 294mm Vented
Brake disc thickness: 21.9mm
Minimum thickness: 19.5mm (FN44 brake caliper = 18mm)
Brake Fluid…………………………………………………………………................ DOT4
Windscreen washer additive .............................................. VW Part No: G 052 164 M2
Sonax ClearView
Suspension
Rear Springs
King Springs P/N KVRR18 rised springs from Repco or Pedders are useful and economical (~$350) addition to raise ground clearence at the back (by 50mm approx.). Anything beyond that seems to get into big money.
Rear Shockers: VW p/n 7H0513029D MONROE made in Belgium or more heavy duty Pedders P/N 120216 designed to match
Bilstein options for the rear shockers
12.5600-S. is for low weight
12.5600-M is for medium weights
12.5600-H is for frequently carrying heavy load
Rear shock part number: Sachs 313031
Pedders Heavy Duty coil springs P/N 7891 (are also raised springs)
4MOTION off road capability
Hill climbing 37 deg
Approach angle 21 deg
Departure angle 17 deg
Ramp angle 14 deg
Wading depth 300mm
all measured with standard equipment and full load (sourced from VW)
Brake disc front
Height: 55mm
Sonax ClearView
Suspension
Rear Springs
Ramp angle 14 deg
Wading depth 300mm
