Multivan with 19's and 40mm lowering springs
  • Multivan with 19's and 40mm lowering springs
    It took a while but I’ve finally got the 19” rims on the Multivan and lowered it using H&R springs. The springs have only been in a week and at this stage the ride height has dropped about 25-30mm in front and 40-45mm at the rear.
    from this:
    to this.
    Looks much better not having the backend jacked up so much and the ground clearence is still very practical.
    09 Multivan TDI 4motion comfortline
    i like it! are they bmw X5 rims?
      Sure are, off an e53 X5. 19"X9" 48p offset front. 19"x10" 45p offset rear.
        Looks good, how are they for steering clearance, do the rub on full lock?
        2018 Skoda Superb TDI
        2010 Skoda Superb TDI
        2009 Golf VI 118 TSI
        2006 Multivan TDI SOLD
          nice dude
          real different with the X5 rims aswell! and 10" at the back !!!!
            You'll have to come to the next SA meetup so we can have a drool
            - Ben
            2008 Jetta 2.0L FSI
              No rubbing problems at all, the front has heaps of room, the rear has about 5-10mm gap on the inner guard and about a 2mm gap to the interior trim when you open the sliding doors
                Look good, are they load rated?
                2014 T5.1 Multivan Tuned by Pendle Performance Australia
                  Tyres are Hankook K110s - 245/45R19 102 load rated on the front and 275/40R19 105 load rated rear. They are an extra reinforced tyre and not cheap
                    Excellent work, would you be able to post a rear on shot to show the width with 10" rims and tyres.
                      No worries, Ill get the camera out tomorrow
                        Blog, Looks great. I did know bmw wheels had a 5 x 120 pcd and X5 wheels had a good load rating. But are there any mods required to the X5 wheels or wheel nuts, or do they go straight on ?
                          The X5 wheels use bolts with a tapered seat so the standard radius head T5 bolts will damage the X5 wheels eventually. I got some aftermarket 40mm long tapered head bolts to use on these wheels. Also the centre bore of the X5 wheel is larger than the T5 hub so I got some steel spigot rings made to locate the wheels properly on the hub.
                          60deg taper bolt 40mm long on left and standard bolt on the right with the black spigot ring that fits into the wheel
                            [ATTACH]4710[/ATTACH]
                            Thanks Blog, Great info.
                              Sounds like fun - how do I findout when and where you guys meet?
