When replacing the brake pads yourself make sure that you check the surface of the brake disc, since it could have the cracks in the surface that could cause the brake disc to disintegrate under heavy braking while driving, which can be very dangerous.
I wanted to replace the rear brake pads today on my T5 and I've noticed that brake discs have cracks in the surface probably right through the thickness of the wall (vented rotors). Instead I had to put the wheels back on and I have to get a new set of discs tomorrow. Rotors have marked the "MIN TH. 0.748”, which indicate they are probably, made in USA or UK.
Van done only 65,000km and these are original brakes.
