Hi all
My 02 T4 van developed a knocking noise today from the passenger side front wheel area today. At first i suspected a cv joint. The noise is intermitant and only occurs while driving straight on deacceleration, not in your typical worn cv joint manner while cornering. The noise is most evident at around 60 - 70klms, and is rotational and has a wooden sound, not metallic like a cv.
It gets progressively quieter as road speed decreases and is not evident at approx 20klms. I can also decrease the severity of the noise by throttle application, to the point of not being able to hear it.
I have had it on a hoist tonight with both wheels removed. The cv boots are all intact, there is no grease leaking from them.
While on the hoist i started my van an ran it up to 60 klms and on deacceleration the noise was most evident from the hub area. However, it does not sound like a typical grinding/whineing wheel bearing noise, and there does not appears to be any noticeable play anywhere.
Any suggestions before i start to pull it apart?? Thanks in advance.
