Hi Guys
I am fixing a vw T3 van for a friend at the moment
its an 89 2.1 watercooled Petrol- not familar with this engine at all if anyone can help.
He managed to roast the engine as it had a small coolant leak from under the thermostat housing and he basically drove it bone dry before noticing.
since roasting it -upon refilling, it has started to leak coolant from around the thick rubber outer head gasket.(between block and head)
I pulled the LHS head off today, The thick rubber gasket is badly maimed so it will require a new of those,
However on inspecting the head i found between the inlet and exhaust valve seats is a small crack, doesnt seem to be cracked into the actual valve seat- just a crack in the head itself, prob 2-3mm long. my fear is will this be allowing compression into the water jacket inside the head??
I have seen cracks like this in other heads before and they dont give any problem but on some engines the crack can enter the water jacket.
Any 2.1 experts offer advice?
Also i have noticed that their seems to be a rubber o ring seal and lots of gasket compound around the top of the liners were they sit into the head,
Is this a special o ring in the liner recess groove or simply gasket sealer?
All help appreciated
Rodge
Rodge
