I bought this caravelle recently and I have been experiencing some juddering when under load.It was as if it was travelling over a rippled surface.I came home and parked on the drive which has a slight incline and it cut out before turning it off.Generally it ran rough with vibration through the body of the vehicle when it was parked on an incline but no vibration when on the flat.It will not start now and there is no spark out of the coil pack.
The coil pack was replaced recently but a second good unit was tried,relay 30 replaced,all fues intact,replaced ht leads,checked all wiring,hall effect unit checked.The garage is suspecting the ecu but it is not a plug and run job because of the immobiliser.
Has anyone got any experience or any suggestions please?.Thanks in advance.
