T3 caravelle, water in oil
  • T3 caravelle, water in oil
    Got a van in yesterday with about 10 litres of oil/water in it FAs I filled the cooling system it was running out of the sump. Haven't counted the headstuds remaining on it yet but the top end was done 5 years ago. I will inform what I find. Don't think that we have any T3 owners here, have we?
    Syncro, do you have one?
    I owned a caravelle til mid 2000 ( ex took it as part of the divorce settlement) the engine was always prone to weeping about the head/ cranckase joint.
    Definately have to be on the ball with cooling system maintenance ( think it was using G12 ??) and the correct way to bleed the air out of the radiator..check the oil water intercooler BTW...mind you , the volume of water coming thru its likely a stud or the case has corroded thru..
    If I still had the vehicle it would likely be running a subaru engine by now..
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
      Yep. Noticed one broken stud yesterday before I locked up. Will investigate further tomorrow> Buggers of motors for that.
        WE have one. Why do you ask?
        Paul
          Just wondering. Don't see many topics on them here, thats all. Cheers!
            Syncro has one too. Where are you Phil?
              Just got back from Valla. Not many Golfs there this year but loads of T3 vans including 9 syncros!
              Normally oil in water is from the oil cooler. Corrosion is caused through people putting tap water in or not using G11.
                This vehicle has always had G11. It has 1 broken head stud so far. Still to pull it apart but I had other things going on this afternoon. Basically I want to share with you what happens to them and will keep you all informed.
                Hey Syncro, bit wet at Valla I hear??? Got any pics?
                  Do you drill the studs out yourself if they snap? We send them down the rd to a drilling place cause there such a B%@# to drill out yaself. I hate pulling out every stud thinking if its gunna snap or not. I reckon T3's are good and reliable cars, my dad has a T3 twin cab ute.
                  MK4 GTI (KO4, GIAC)
                  VW Kombi Ute 2ltr EFI
                  Audi 90 20V Quattro
                    Only wet on Saturday
                      Finally got onto it this arvo. Been busy with other cars. Guess what mk2 gti? Got all the studs loose easily! Had one broken lower stud so the coolant was running in around the rocker area. Glad to have them loose tho! Cheers
                        I love those Snap On stud removers that they don't sell anymore!
