Hi all,
I now have about 4000K's clocked up on the Multivan TDI. I took it for a country run on the weekend. I noticed at one stage that the engine started running rough for a period when in neutral at about 1300 RPM whilst pulled up for little while. I also heard the turbo making slight 'rumbling' noise (almost like starter motor disengaging noise) whilst listening to the engine revving at this point. Having said that, the turbo spins freely, and as it starts to spool up under load from say 1200 RPM there is a whooshing noise -which I suspect is normal as air is sucked into the turbo?
After a while the engine was smooth again.
I did also notice this behaviour one other time on the very first day I picked the Multivan up from the dealer and completed a 500K trip and as I pulled up in the driveway the engine ran rough and the 'turbo rumbling noise'. My initial thought was the turbo is stuffed on brand new vehicle. I have heard that this might be to do with the particulate filter doing its stuff?
What are your thoughts? Could the turbo 'rumbling noise' simply be a air bleed off noise when the turbo winds down and when the particulate filter is burning off. It doesn't sound like a turbo bearing noise and is not an noise easy to decipher. I hear the 'rumbling noise' for a couple of seconds when switching off the engine when the turbo slows down. How quiet should the turbo be on these engines?
Regards,
Scott
Regards,
Scott
