My current shock absorbers need replacing and I was wanting recommendations for a good quality replacement that'll cope with extended driving on gravel roads/tracks eg Oodnadatta track. I've been looking at Sachs HD which are twin tube oil filled dampers, or would gas filled Bilsteins be better or any other recommendations. Cheers
T4 Syncro Shock Absorber Recommendations
I wouldn't go past a Pedders for any sort of shock absorber be it struts or regular. Apart from damper quality Pedders have a good network to fall back on and, if the unlikely happens and the shock absorber fails Pedders cover the replacement and labour costs involved. Other manufacturers/distributors generally want the shock sent to them for evaluation and they mostly won't pay the labour costs. Cheers-John
Originally posted by Mutleee View PostMy current shock absorbers need replacing and I was wanting recommendations for a good quality replacement that'll cope with extended driving on gravel roads/tracks eg Oodnadatta track. I've been looking at Sachs HD which are twin tube oil filled dampers, or would gas filled Bilsteins be better or any other recommendations. Cheers
Definately Bilsteins!
I've used them on many vehicles and have them (Bilstein B4 I think) on our T4LWB. The ONLY exception to Bilstein would be Koni Yellow. Monroe, Peddars, Boge etc are OK on a lightweight car for a short time then turn to mush.
We fitted Bilstein B4s to our T4 before a trip to Lake Eyre a few years ago & they are still tight now. They do a lot of work on a heavy van like these. For interest, I stopped after a particularly rough part of the Oodnadatta track & felt the front shocks. They were hot, not hot enough to burn my hand but hot.
I have bought Bilsteins from USA cheaper than local source but this will depend on the exchange rate at the time. Australia seems to get a bad deal on their pricing.
Regards,
FarmSyncro
Originally posted by Mutleee View PostThanks Seano. Sounds like a good recommendation for Koni. Can I ask where you managed to source them? I've had a search on google and can't seem to find anywhere. Cheers.
Edit: current distribution into Oz is done by Toperformance in Melbourne and they have agents in most capitals
Distributors – KONI Australia – Toperformance Products
If you can't source them then the Bilsteins are an option though I've personally found them too hard in the vehicles I have used them in in the past...Last edited by Seano; 26-10-2020, 08:10 PM.
