Magnetic Insect Screen For T4 & T5
  • Magnetic Insect Screen For T4 & T5
    Came across this site for insect screens, thought it may be usefull with the fly season coming.
    Numerous Mk1 Golf diesels
    Can not seem to get on there site at the moment
    Will have a look later.
    Good idea by the sounds of things...
    Rob
      Link seems to work OK, maybe they were all asleep when you tried.
        Found it...realise the thread is 5 years old...has anyone got any more information about this type of product.
        Am thinking about a sliding mid window...but maybe this makes more sense.
        I need to sleep in the van sometimes when working overnight...and even in industrial areas there's damned mozzies
        __________________________________________________ __________________________
        VW Transporter T5 MY10 Van M 6spd 2.0DT 103kw White. Long wheel base. Standard roof?
          Yep they work ok, got them on my LWB, have used them a fair bit, with it when I got it.
            Hi aSimpleLife, I have a T4 campervan that we often sleep in. To keep the mozzies out I just cut some flyscreen to size and used self adhesive magnetic tape from Officeworks to secure it over the outside of the driver and passenger windows.
            They work really well and are inexpensive. They are quick and easy to put on and take off and you can still wind the windows up and down as necessary!
            GC
              Thanks very much for that.
              If it's as easy as going to OfficeWorks then I should get off my but and just do it.
              And with the insect screen, is there any type that is best?
              I've got a recreational vehicle store near me - would that be the best place to source the insect screen from
                This is the tape I used Magnet Tape 3m Roll | Officeworks tape and I just used normal nylon fly screen from Bunnings so that it didn't scratch the paintwork.
                I also replied to your other post if you are looking for something for when it is raining or if security is an issue.
                GC
                  Thankyou again.
                  Have followed up your other post too thanks.
                  Looks like at this stage I'll use this insect screen construction and see what else appears over time.
                  I must say I am happy not to waste a perfectly good bonded window - even though in hindsight I should have put in a sliding one in the first place.
                  At least my procrastination seems to be working to my advantage this time
                  I'm off to OfficeWorks and Bunnings as we speak.
                    Well I've spent my $12.90 (including GST so all I've got to do is make it a priority on the near queue...and not stick it on the pile that is my dastardly far queue.
                    Looking at your picture for the T4 version, I see that the short edge has no magnetic tape, so assume that runs into plastic there?
                    With the T5 the whole long bottom edge is plastic. So I suppose I could just leave the insect screen a bit longer to hang over the edge and that should seal things well enough? Not sure I want to use velcro or anything attached to the plastic door trim for the few times that I require this. Unless anyone has any suggestions?
                    topgear2go.com.au have got back to me regarding insect screens for the front drivers and passenger windows for a T5. They have an inside fitted option and an outside one.
                    External fitting door window magnetic insect screen for VW T5 that do not have weather shields installed: Price $80 per screen plus P&P
                    Internal fitting passenger door window magnetic insect screen for VW T5: Price $95 per screen plus P&P
                    I'll try and attach the pics now.
Name:	Outside Fitted from Outside.jpg
Name:	Inside Fitted from Outside.jpg
Name:	Inside Fitted from Inside.jpg
Name:	Inside Fitted from Inside (2).jpg
                      Yes, because of the plastic mirror surround there is no metal for the magnets to stick to in this area. I found though, with the correct tension, the fly screen would sit flat in this area and keep out any unwanted pests.
                      I would put one on and take a photo but I now have full weather shields fastened to the front doors. Ventilation is now by way of a screened sliding window and a roof vent.
                      GC
                        At the risk of going off topic, what sort of sliding window did you end up getting fitted?
                        And why did you do that if you were happy with your insect screen solution on the front windows?
                          The sliding window was already in the van when I bought it. Because it's used mainly for camping and touring, security was an important factor so I looked at other alternatives. Ended up screening the slider with amplimesh and installing a roof vent with a small 12v fan in it.
                            Thanks for that.
                              I never was much of a handyman and I was not very happy with the quality of my attempt at making one myself.
                              Being a business expense I purchased from Top Gear 2 Go a Drivers and Passengers door window version. I got the internal fitting version for both just in case I wanted to put visors on the windows, and as they are just that little bit harder to steal.
                              Quality looks good and the fitting instructions were ok.
                              I did have one problem...although that could be just me being me...with positioning the adhesive strip along the bottom on the sill. I found it ambiguous how to fit the shape at the bottom at the bottom back corner...and as a result didn't put the adhesive in the right position first attempt. There was no photo of this area in the instructions which would have helped. And in my defence, while both Australia Post tubes were marked left and tight...unfortunately they had put the wrong one in the wrong tube...which took me a while to work out.
                              I have also purchased one of those ebay sliding door insect screens. Some notes about that are posted here;
